w220 s500 xenon headlights
I have two questions..I have year 2001 s500 with factory xenons, do i get any errors if i change headlights to halogen version? Seems connectors fits. Right now it has Depo xenon headlights. if i change them to like this? https://www.ebay.com/itm/CLEAR-PROJE...LH_TitleDesc=0
I see my connectors are same.
Xenon headlights for that model is hard to find.. a lot easyer for 02-05 model and cheaper.
Other.. basicly i need new right side lens..Wich would be better buy? https://www.ebay.com/itm/273350400623?ul_noapp=true or this? https://www.ebay.com/itm/Right-Side-...-/322481539601 Im not sure if they fits.
Hello and welcome to the forum! A retrofit kit should include everything that you'll need so your car will not throw any error codes. Can I ask why you want to replace the entire housing? Are you just needing new xenon bulbs to replace? Lens, I would be careful about; as fitting securely is very important to prevent any moisture from getting inside.
Here is a link to xenon bulbs for your car - if you'd like to call us and confirm that they'll work/fit; you can do so by calling us at 888-280-7799.
https://www.pelicanparts.com/catalog..._pg1.htm#item0
