Trunk access help
Old Feb 11, 2007 | 01:02 AM
philcons's Avatar
Default Trunk access help
I have an 2000 S500
My battery has died due the cold weather. All the electrics are down.
I cannot open the trunk to access it.
I can open the hood.
Is there some where to apply electrical power to operate the trunk latch so that I can gain access to the battery??
Marty
Old Feb 11, 2007 | 09:18 AM
snanceki's Avatar
Default RE: Trunk access help
In simple terms you have to apply power to somewhere along the main power busbar / wire (RED) which runs from rear to front of the car. (w220?)
I believe you can gain acess to such a terminal in the passenger footwell under the toeboard carpet
after entering the car using the mechanical key.
I guess you could also use the terminal on the starter motor but this will be difficult to access.
If it is a w140 I'm sure it will be the same but am not familiar where the battery is. i.e. Engine bay or boot.
Hope this helps.
Regards,
Stuart.
Old Feb 11, 2007 | 09:20 AM
sleepwalker's Avatar
just use the mechanical key.
Old Feb 11, 2007 | 03:28 PM
cbeastwood's Avatar
Yep - same thing happened to me this week.
Just stick the mechanical key in the trunk lock; turn key 90 degrees and push on the key. It should pop right open.
- Craig
Old Feb 13, 2007 | 01:13 AM
philcons's Avatar
The mechanical key is in Vegas
But... I attached a small charger to hot lead of the starter and after 20 minutes I had the battery up enough to get the trunk open.
Anyway she is charged and working fine.
Thanks for the help gentlemen
Semper Fi
Rudy-mbz
Sep 24, 2013 02:30 PM
dee2000
Jul 21, 2011 07:43 PM
walkerct
Jan 26, 2008 02:23 PM
cbwhitley
Aug 15, 2007 04:44 PM
mark1668
Jul 6, 2005 09:16 PM
