Transmission Oil leaks
Old Jan 16, 2010 | 08:43 PM
Robert_88's Avatar
Default Transmission Oil leaks
Hi all
new to the forum, owner of a 2001 S 320 40,000km only. recently has oil leaks, fixed once and still leaking. Went for a long distance run this morning and discovered the temperature went as high as 90C. Checked coolant and oil levels are fine.
Please advise course of actions.
Cheers
Robert
Old Jan 18, 2010 | 12:35 AM
Rockerfella174's Avatar
hi robert88,
does your merc still got the oil leaks? Do double check with the workshop that you fix with. it might be the hardening oil ring located with the big wires located on the rear left side of your ATF transmission oil pan.
ok.. now back to your temperature problem.. Have a mechanic who has the pressure pump kit to test if there is any coolant leaks.
Possibility for items need to have a look upon
1. from the hardening fiber plastic radiator
2. possible leaks from the radiator hose
3.radiator cap
4.thermostat valve
5. The motor cooling fan
These are the possibility base upon what Ive repaired & experience while fixing on those models.
update us with the results and share it with the forums readers
good luck
Rockerfella174
Old Jan 18, 2010 | 03:11 AM
Robert_88's Avatar
Hi Rockerfela 174
It looks like the oil leaks has stopped. I have booked for a check up this Thursday and will certainly share with all the results. Your explaination re: the hardening of the oil ring makes a lot of sense.
Thank you for your inputs.
Regards
Robert Teo
Old Jan 20, 2010 | 07:26 AM
your most wellcome robert
rockerfella174
brunei darussalam
amalfi
Jul 8, 2010 05:49 PM
kierankeyes
Jun 5, 2007 02:24 PM
bchengwa
Apr 9, 2007 12:45 PM
noslowturbo
Jan 17, 2006 05:43 PM
mfkenney99
Jan 5, 2004 09:52 AM
