Taking off timing belt
Old Sep 10, 2007 | 06:00 PM
gixxer's Avatar
Default Taking off timing belt
any tips how to? because I need to get it off in order to take alternator off and I have trouble finding tensioner can find where its located...
Old Sep 10, 2007 | 06:58 PM
chassis221's Avatar
Default RE: Taking off timing belt
in the pic i sent you its sort of a bad picture but you can see the belt tensioner it is the middle pulley, the one on the right is the powersteering pulley and the one on the left is the crank pulley. the tensioner is in the middle, yours might look different than the one in the pic. the one in the pic is theupdated model. yours could have a torx head in the middle of the pulley to move it if its the old style if you do have the new style you need a 17mm to move the tensioner and the 17mm head is visible just to the left of the tensioner pulley. you can just barely see the 17 mm screw at the very bottom of the pic. its not actually a screw just a 17mm size head to move the tensioner.
[IMG]local://upfiles/20215/1776F7D17D0044279FFFE6E9FD4F72B3.jpg[/IMG]
Old Sep 10, 2007 | 07:10 PM
gixxer's Avatar
Thanks I got it
btw way do you know if altarnator is hold by only 2 bolts or there is something else on the back?
Old Sep 10, 2007 | 07:16 PM
chassis221's Avatar
just the 2 bolts but becareful when taking them out and putting them in they tend to cross thread. use some antiseize when going back in and clean the threads a bit. you might want to press the metal ring in, around where the bolts go threw the alternator brackets so it will makeinstall easier.
Old Sep 10, 2007 | 07:19 PM
gixxer's Avatar
alrite, thanks again, sounds like you're the one who invented mercedes benz
Old Sep 10, 2007 | 07:29 PM
chassis221's Avatar
well just been screwed a few times by a Mercedes Benz. if you break the mounting brackets the correct repair is to replace the whole front cover of the engine and that has happened to me before, but thanks!!!
Old Sep 10, 2007 | 07:42 PM
gixxer's Avatar
ouchthats sucks... one more question, how the hell do I take the alternator out? do I take the fan off or something, because it looks like it cant go thru that opening
Old Sep 10, 2007 | 07:59 PM
chassis221's Avatar
if you have a 430 engine you should be able to get it out by twisting or turning the alternator but if you have a 500 you might have to take out the auxillary fan which is pretty easy, like 2 screws but you have to work around the trans coolant lines and rad hoses, or you can remove the screws on the top of the rad support next to the 2 hood latches and then move the rad frontwards a bit it should give you some movement maybe enough for clearance.
Junger
Mar 20, 2013 05:38 PM
MBSL560
Oct 27, 2011 05:26 AM
soadfreak1915
Sep 26, 2008 05:56 PM
Slkboi2000
Sep 5, 2006 07:01 AM
racerxsw
Oct 8, 2004 01:07 AM
