S430 Front Seats Memory
Hello,
I was wondering how does memry on front seats works in 2004 S430. Is there a counter in a motor or is there a sensor that memorises position of the seat??? Thanks |
RE: S430 Front Seats Memory
there's a hall sensor on the motor and the corresponding door control module remembers the position.
once the battery is disconnected, this memory is lost... the reason why easy entry doesn't work and the headrest got memory too. you need to initialize them. fore-aft, up-down, backrest forward and backward tilt. |
what do you mean initialize them?????
programming
initalization something to tell the control module the basic end to end position what was the problem anyway? [sm=imsmilin.gif] |
i'm taking the seats off, cuz there's some signs of water under it,and there's some corrosion, so i'm just wondering how will memory work after i put them back
thanks |
memory is kept in door control module.
it doesn't matter. |
i'm gonna buy new motors and some other little things, and when i'm gonna put it all back together, the memory will work??
if you will change the motor, you will need to initialize the seat.
just actuate all seat movements from end to end. that will do it. |
oh OK, thanks for the great info:D
