S-500 2000 command radio removal
Can anyone advise how to remove the command Navigational Radio from the dash. I assume the wooden bezel just pops off but I don't want to crack it.
Thanks, Dean |
RE: S-500 2000 command radio removal
pull out the ashtray housing.
got two torx screws behind it. unscrew and pull out the covering. |
Sleep walker
I have a 2004 sl55 and have recently purchased a dice ipod conversion kit that reportedly is plug and play replacing the cd changer. How do you remove the cd changer housing and gain access to the changer to replace it?Do you even recommend it? Thank you! |
I presume you have found the solution by now.
However for the sake of the forum here is how I removed mine from my ’00 S-430. Put on park brake Turn ignition switch on Place car in neutral Open the ash tray compartment Remove the torx screws on each side After the torx screws have been removed close the ash tray compartment & remove it The wood bezel has snaps on each side located in the 3 and 9 o’clock positions Take your time unsnapping these snaps, one side at a time Remove the 6 torx screws securing Command Unit Now the Unit can be removed[/ol] |
| All times are GMT -5. The time now is 03:50 AM. |
