REPLACING CABIN AND CHARCOAL FILTER
HELLO MB ENTHUSIASTS!
I'M A NEW MEMBER, AND AM SEEKING ADVICE WITH CHANGING THE CABIN AND CHARCOAL FILTERS IN MY WIFE'S 2001 S500. HAS ANYONE ATTEMPTED THIS TASK? I'M ASSUMING THE FILTERS ARE BOTH LOCATED BEHIND THE GLOVE BOX, PLEASEGIVEME YOUR VALUABLE INPUT. |
RE: REPLACING CABIN AND CHARCOAL FILTER
yes. behind the glove box.
clear the glove box and you will see a concealed screw on top and bottom. remove the sovering to see the screw...just pry it. pull out the glove box...detach the lock catch and illumination lamp. slide the clip on the dust microfilter and remove the cover. you got two filters inside! |
I want to do my 95 S500 charcoal filter too. Would you direct me how to perform this task? Thanks
remove the wiper assembly and you will find it.
Do you mean under the hood and below and next to the windshield? I saw a lot of square bolts on the black plastic where the water comes down thru the openning from the hood. Am I right?
Thanks |
