i need help with my 1987 420sel
i have had two main problems with my car. one of them is when i turn my key to start it makes a clicking noise under the abs cover and will not even turn over. another problem has occured with my transmission, it will only stay in 2nd gear but if i acclerate enough and i let it roll in drive it will kick into gear. please someone help me.
tllnya |
RE: i need help with my 1987 420sel
can you be more specific which area the click is?
maybe low battery? loose battery connection? faulty starte? seized engine? about the transmission, is the control cable in proper adjustment? |
there is an abs box and under that is a relay i think and that clicks, and were can i locat the control cable? |
anti-lock brake system? which area?
or abs plastic? |
abs plastic were is the control cable
[sm=dontgetit.gif]
Lol, i think my 91 420 SEL has the same shifting problem as yours. It might just be the car having all that torque and not a lot of acceleration.
