Help on replacing spark plugs
Old Feb 25, 2007 | 04:10 AM
yikee's Avatar
Default Help on replacing spark plugs
I have a 2001 S500 that need to replace all spark plugs, Is there a special tool to change it? Any comments from the forum.
Old Feb 25, 2007 | 04:19 AM
snanceki's Avatar
Default RE: Help on replacing spark plugs
No.
Just tricky, time consuming. Poor access.
Use open ended spanner to get plug leads off since they tend to stick.
Remove air cleaner to improve access.
Stuart.
Old Feb 25, 2007 | 11:02 AM
coolvt's Avatar
What is the recommended time on these...100,000 miles?
Old Feb 25, 2007 | 01:43 PM
snanceki's Avatar
Not really sure what the change point is since it seems to change dependent upon territory (maybe due to gas quality).
Euro fuel is of higher octane than in USA.
My experience is on V6 M112 engine which appears to be recommended at 70k miles in Euro service recommendations.
However, in one of my cars they are running fine with little wear at 100k miles and no problems what so ever.
On the M112 V6 there are two plugs per cylinder. Not sure if this is also true on V8.
The Platinum OE replacement plugs (Beru) are expensive.
My personal preference is to use OE parts (even if not MB branded) since these have been extensively tested by MB.
Don't believe all the hype you read about this make or that giving you better gas mileage etc. and be wary of three electrode tips etc etc.
Stuart.
PelicanParts.com
Dec 1, 2017 04:15 AM
kzukowski
May 2, 2011 09:44 PM
allboostnojuice
Apr 6, 2011 06:33 AM
Andybenz
Jul 10, 2009 10:31 PM
swoody
Sep 25, 2007 01:41 AM
