Fuel Indicator (Malfunction)
Old May 20, 2007 | 06:58 PM
Mercedesgolf's Avatar
Default Fuel Indicator (Malfunction)
[:-]I have a 1996 S420 59K miles in immaculate condition and well maintained. Fuel indicator will go down to empty while driving when tank is full. Few seconds later, it will general go back to proper fuel setting. After several malfunctions, when it malfunction once again, the check engine light came on and is now still on. However, as usual the fuel indicated went back to normal. I need help?
Thanks in Advance
Old May 20, 2007 | 10:04 PM
ARMENDS500's Avatar
Default RE: Fuel Indicator (Malfunction)
your fuel sending unit is bad, i am not sure how to change it on your car.
on my 00 s500, it was located behind the carpet trim in the trunk.
very easy to replace if you can locate it.
Old May 22, 2007 | 02:00 AM
Rockerfella174's Avatar
Could that be the fuel floater in the tank ?... it did happen to other japanese cars i did fix before...
paul0120
May 30, 2008 10:10 PM
harryco
Jan 10, 2008 12:34 AM
webberkyle
Oct 16, 2007 09:53 PM
webberkyle
Oct 15, 2007 11:58 AM
benzowner
Jun 5, 2007 11:52 AM
