What is your car normal ride height?
I'd like to survey S owners to find out normal car height assuming corect tire size. Since there have been so many issues reported with airmatic system, also considering that the earlier they are repaired the cheaper it is, this info would allow ownersto quickly detect when the airmatic is leaking or about to go dead.
All measures areflat surface, empty car, from wheel well edge vertically down through virtual center of wheel
1. what is your normal car's height in the morning before start?
2. after start?
3. what is maximum height if car is raised to max height?
4. does temperature affect your car's height?
I will post my 01 S500 numbers once I measure them later.
2. after start?
