92 mesedenewbie please help !
Old May 9, 2006 | 12:06 AM
DERCUR's Avatar
Default 92 mesedenewbie please help !
I have a mercedes s600 , which has been stored for over a year ,the car has also been without a battery for the same period of time . but was in perfect condition when parked .just brought a new battery and tried to get car started but was not sucessful ,not sure if car need to be programmed or if the fuel is not working , car doesnt seen to be getting any fuel, any suggestions
Old May 9, 2006 | 12:49 AM
sleepwalker's Avatar
Default RE: 92 mesedenewbie please help !
then it is best to check the fuel pressure or even just the fuel delivery quantity.
you must be able to get 2 liters in 1 minute.
Old May 9, 2006 | 03:14 AM
DERCUR's Avatar
i took one of the fuel line loose and its not getting any fuel to the injector also I cannot hear the fuel pump. is it possible that the fuel pump has gone bad for being stored
Old May 9, 2006 | 03:30 AM
DERCUR's Avatar
where should I start should the system prime itself or will the tank need to be preassurized help!
Old May 9, 2006 | 03:55 AM
gravity takes care of it.
just make sure the fuel pump works and got fuel inside.
Old May 10, 2006 | 03:35 PM
DERCUR's Avatar
ok found the problem ,pumps need to be replace .thanks alot , also once I replace these pumps will you be able to help me with the radio reset
Old May 10, 2006 | 10:34 PM
for as long as you got the radio code.
Old May 11, 2006 | 02:56 PM
DERCUR's Avatar
the radio just says waiting , do I have to remove it to get the code or is there another way
MARIODRIVE
Nov 23, 2008 05:39 PM
lubee84
Feb 16, 2008 10:29 AM
sql123
Dec 1, 2007 12:11 AM
ezeneli
Apr 8, 2005 03:05 AM
siddiqui2000
Feb 16, 2005 01:16 AM
