-   Mercedes S Class (https://mercedesforum.com/forum/mercedes-s-class-11/)
-   -   91' 350SD engine issues - need advice (https://mercedesforum.com/forum/mercedes-s-class-11/91-350sd-engine-issues-need-advice-37055/)
tigerpaw Jun 7, 2009 11:57 AM
New here, from NJ. Need advice on engine issue, and a reliable mechanic that will not gouge my money. I don't mind paying for good work though.
Some background before I describe the problem.
Car bought in summer 2002 at 90K miles. Engine failed in early 2003: crank-shaft of one cylinder broke through the engine block! Oil went out and engine froze.:mad: Got it fixed under 1 year warranty with much back-and-forth with the used car dealer in Elizabeth, NJ. Car ran OK for a while, but never felt it was good ...
Engine problems:
- heavy thumping at idle in drive
- extremely rough sounding (feels like it might break again!:eek:)
- thumping quiets down a little in park (reduced load on engine?:confused:)
- very smokey on acceleration around town; less smokey at hi-way speeds
- in general lacks power (has hard time keeping up at 65mph)
- oil consumption is high; 1 qt every 100 miles :(
After all these years I have still kept the car ... that may be stupid, but I want to see if it can't be fixed. I have already spent much just on insurance to keep it around, so not willing to spend too much more if it's a lost cause.
Which NJ/PA mechanic would you recommend to take a look at the problems? What can I check myself? I have most tools and am mechanically capable.
Thanks in advance!
tigerpaw Jun 8, 2009 12:47 AM
Bump
Bump!?
barnes Jun 23, 2009 10:11 AM
sounds like rings worn out as it uses so much oil--have the compression checked by ANY mechanic---diesel should have relativley HIGH compression as compared to a gasoline engine---this would explain a lot of what is described in your post--
I think the glow plug port[not easy to get too] will be the spot to check compression--but i'm not an expert in repairs on the engine-- does it start up quickly?? this is another "clue" as to compression ratio. Hope that you find something else as an overhaul is quite expensive--but then you would be good for MANY MANY more miles on the diesel.
good luck
barnes
1991 350sd---167,000 miles---2nd owner
vytamenc Jul 8, 2009 01:13 AM
way to hard to diagnosis your car with out seeing it and driving it take it to shop.
