22' on a S550
Old Nov 18, 2012 | 05:42 AM
SLC550's Avatar
Default 22' on a S550
Hello all, trying to get some feedback. Got a 09 S550 love the look of 22' wheels on the S class, but wondering about the TPMS. So my ? Is do they have wheels that have the sensor or can you use the stock sensor. What do I need to do to make sure that light stays off.........Thanx
Old Nov 18, 2012 | 10:42 AM
chassis221's Avatar
it depends on the wheel and tire. the sensor is apart of the valve stem. normally the tpm sensor rests on the inside of the wheel. If you use the same sensor, if you can and if it does fit into the new wheel, you might be able to use it. it might not rest on the wheel and therefore also could get damaged while installing a tire on the wheel. especially if you have a very low profile tire. on some of the tpm sensors there is a very small amount of movement for adjustment. you can't just use any tpm sensor. diffrent benzs have diffrent sensors and wont work with other tpm monitor systems.
you can always just use regular old valve stems and just ignore the light.
Maksimus
Nov 13, 2020 03:16 PM
Paulilii
Jul 2, 2011 07:27 AM
Maksimus
Feb 14, 2007 08:08 AM
S550BLK12
Apr 13, 2006 12:08 PM
suh1234
Mar 16, 2006 04:52 AM
