2001 S430 misfiring and cutting out above 3K RPM
Old Oct 27, 2008 | 01:30 PM
ELockhart's Avatar
Default 2001 S430 misfiring and cutting out above 3K RPM
The problem started a few weeks ago. Could it be the electronic gas petal again. Just had it replaced a year or so ago. I suppose it could be many things. The problem has been intermiten for a few weeks. It seemed to have gotten a lot worse since I left the key in it and the battery went dead. Any help would be appreciated.
Eric Lockhart
Old Oct 28, 2008 | 04:20 PM
jrhilton's Avatar
Default RE: 2001 S430 misfiring and cutting out above 3K RPM
ORIGINAL: ELockhart
Eric Lockhart
Why exactly did the battery go dead, are you sure your alternator and related electrics are in perfect working order.....S classes have (or are meant to) high capacity batteries so I would not expect your battery to go dead quickly if you just left the key in the ignition?
Does the engine cut out if you put the autobox into "Limp home mode" (assuming your newer S-Class has this feature), and take the engine to over 3000RPM?
One interesting test would be to get up to speed on a safe empty road, have autobox into Drive, drive along and set cruise control on, then move the gear selector down to 4, then 3 and see how high you can get the engine RPMs. I'm not sure about 1999-to date S-Classes but in the older ones you could actually shift down a gear and the cruise control would not disengage if you have winter mode selected.....if this works fine...maybe its your gas pedal?
If the above doesn't work....set your autobox to 2nd gear, and engage cruise and increase the cruise speed to take up the engine revs. See if that works, if your engine doesn't missfire doing this above 3000rpm, it implies it could be something to do with your gas pedal...
If it does keep cutting out, at least you will have some useful info for your local garage about all the situations it cuts out to allow them to pinpoint the problem even quicker......
Mr.Gordon
Feb 20, 2013 05:19 PM
gongie
Jun 22, 2010 04:22 PM
rsxvscell
May 14, 2010 11:15 AM
gpharper
Apr 23, 2009 02:53 AM
Si Gibson
Nov 17, 2006 08:49 PM
