1995 s500 Car problems
1) high beams wont come on is there a relay switch or fuse . I changed my high beams and checked all fuses. I was told it could be the switch on the steering wheel or a relay...
2) My right front window stopped going down. I use the switch and I hear the motor just the window isn't connected to it. I can push my window down with my hand....Help...I pulled the door panel off I just don't know how to the window is connected to the motor and how to fix it |
RE: 1995 s500 Car problems
does your flash to pass high beams work...pulling the stalk backwards? or are both of them inoperable.
The window might have came off the track. I had that happin on my older Mercs.
coming off the track is too far fetch to be accurate, cehck your window regulator, and see if the cable have jump off the plactic wheel track, only way is to post picture for more accurate advice. If in case the window regulator is broken, there is no repair jsut replace with another one, there are many replacement brand for it and will cost around 20 dollars and will be good as original.
flash to high beams do not work
so you get no high beams with pushing the stalk away from you or pulling it toward you?
I get nothing only thing works is my low beams and fog lights
| All times are GMT -5. The time now is 10:10 AM. |
