-   Mercedes S Class (https://mercedesforum.com/forum/mercedes-s-class-11/)
-   -   1995 s320 heating/ac problem Help Please (https://mercedesforum.com/forum/mercedes-s-class-11/1995-s320-heating-ac-problem-help-please-2651/)
shaynecrowe Oct 16, 2004 03:38 PM
HI again and thanks for everyone's help with my last problem!
Just turned on my heat for the first time this year and I can't get any heat from the driver side vents. Only heat from the passenger side. The AC works as usual. Any suggestions, thoughts?
Thanks for your help.
Shayne
cool Oct 16, 2004 03:49 PM
RE: 1995 s320 heating/ac problem Help Please
Hello,
Try switching or turning the center vent control, located on the buttom of the center louvers. they might be turned off, if not please be more specific with your problem, good luck.
shaynecrowe Oct 18, 2004 11:17 AM
It is not my vent controls. The air blows out of the vents, it is just cold on the driver side. No heat will come from the dirver vents. The a/c blows cold on both sides but when I turn both sides to a higher temp setting, heat only blows from the passenger side vents and cold air continues to blow from the driver side.
jome Oct 24, 2004 05:11 AM
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step.
A great help, hope this will help you.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
:D
