1995 S320 A/C Compressor Not Running?
Hi Sleepwalker, I have a 1995 S320 model. For some reason the A/C stop blowing cold air and I did checked for a few things, but couldn't figure out what sensor, sensor switch, or something else could cause the compressor stop working. There is no current going to the compressor.
I did check the following: 1. There is still enough freon in the system. 2. There is current at the pressure switch, the one that screw to the dryer. 3. There is current at the A/C off emergency sensor. 4. The fuse is fine. Thank you very much for your help... |
