1992 S500 coolant leak
Old Aug 11, 2006 | 10:49 AM
everlyne's Avatar
Default 1992 S500 coolant leak
Car model, 1992 S500 W140
Recently power steering fluid leak behind the reservoir. This is followed by coolent leak from the middle section of the engine. After opening the under cover I saw a number of leaks. The coolant, Power steering fluid and steering box. Appreciate you guys advise where to start. Wounder where can I get workshop manual.
Thanks.
Old Aug 12, 2006 | 12:51 AM
everlyne's Avatar
Default RE: 1992 S500 coolant leak
I have notice the coolant leak is right below the water pump. Can anyone tell me how do I check if it is the water pump leaking or just the hoses connecting to the water pump. Appreciate your help.
Old Sep 8, 2006 | 08:26 AM
everlyne's Avatar
The coolant leak only when the engine is warm (ie at normal operating temperature). Any ideas. Is there any internal seal? Where could the leak be?
Old Sep 8, 2006 | 08:56 AM
97dmsrS420's Avatar
You can do a Search on this site, and you will find where you can get a WorkShop Manual. Good luck.
Old Sep 10, 2006 | 06:18 AM
everlyne's Avatar
There is a small hose connecting from underneath the water pump and the small hose runs downward connected to a black plastic box at the lower side of the engine. The coolant was leaking from the black plastic box. What is the purposes of this box. Is there a DIY showing how to change this small hose? What else do I need to look out for? Appreciate your help.
Old Sep 13, 2006 | 08:15 AM
everlyne's Avatar
Searching through the site confirm the water pump seal is leaking and therefore coolant leak through the weep hole. Someone mentioned the seal can be replaced BUT it is better to change the whole water pump.
That all folks.
Old Sep 13, 2006 | 11:55 AM
97dmsrS420's Avatar
There ya go....[:@]
JERSEYSURFER
Oct 2, 2008 01:03 PM
hennesseystealth
Mar 4, 2007 02:13 PM
Randy
Mar 15, 2004 12:36 AM
rostov
Jan 8, 2004 08:19 PM
teeman
Dec 11, 2003 09:34 AM
