wheels for 06 r350
anyone know the wheel specs on a r350, i am pretty sure it is very similiar to the ml350 i am curious on the offset, and is the center bore still 66.6 and the lugs 14x1.5
thanks |
RE: wheels for 06 r350
Depending on the size wheel you want, the fit should bea 8.5-9.0 inch wide with a 40mm-45mm offset. 9.5-10 inch should be a 55-60mm offset. 20' tire size is 255/45-20 or 275/45-20 (tall). 22"- 265/35-22 (8.5-9.0) or 295/30-22 (9.5-10).
Hope this helps! |
