R500 Only Works In Reverse
I got an R500 that only drives in Reverse. In D it revs up but does not drive, Could this be the conductor plate??
Hello and welcome to the forum! Before spending any money on parts, I would suggest that you pull the car's fault codes. Even if your CEL isn't on, you'll likely have stored codes that should give you a good idea as to where the issue is coming from. Please let us know if you have any other questions or if we can assist with any future part needs. Best of luck!
| All times are GMT -5. The time now is 10:10 PM. |
