-   Mercedes R Class (https://mercedesforum.com/forum/mercedes-r-class-40/)
-   -   Adblue starts left (https://mercedesforum.com/forum/mercedes-r-class-40/adblue-starts-left-61313/)
Paco0505 Nov 19, 2021 11:18 PM
Adblue starts left
I have a R320 CDI, I have replace the AdBlue Preheater Heater, after 1 week, i had a message to fill Adblue, i have filled it full,1 week later, message 20 starts left. now i decided to bring it to the dealer, They say to replace the Adblue Pressure sensor ?, did anyone ever seen this problem yet, also got 2 codes 1 is temp sensor by turbo and 2 is EGR temp sensor.
Looking for feed back
Dealer info, Temp sensor Turbo- 0071536628
EGR temp Sensor - 6511530028
Adblue Pressure Line - 2514796864
thanks
paul d
LowDown Apr 11, 2023 05:29 PM
Do you have any news on how the problem was solved?
Just wondering.
I had a similar situation and replaced those 2 sensors, then decided to programmatically disable the AdBlue system completely without removing the DPF filter.
Bought an OBD plug from OBDTUNE dot com, brilliantly simple solution to AdBlue problems. For opponents of a complete shutdown, the team created an OBD plug that can reset AdBlue errors - it's the kind of solution where you don't have to call a tow truck if you're stuck in the middle of the road away from the dealer, and will help solve problems temporarily and drive to the dealer in peace. Doesn't disable AdBlue, so it's completely legal.
