vehicle dies while driving
so, my mom has a '99 ml320. she told me that when she's driving, the vehicle just shuts off out of nowhere. it usually happens when she is at a stop, but happened twice while driving. after the vehicle shuts off, it will crank, but not start. so she usually has to wait about 15 mins at least and it will start again. is this a fuel problem or is it something else? i think it may be the fuel filter or injectors. someone else said it may be the fuel filter as well. i'm not too sure how to go about this. any help would be greatly appreciated. the mileage is 86,000 if that helps.
RE: vehicle dies while driving
crank sensor behind motor driver side.
I had the same problem at stoplights and it turned out to be the air conditioning. They had to replace the fans and recharge the refrigerant.
what's the difference between the single clip connector and the double clip connector? my ML's a '99 if that helps
I agree, it sounds like crankshaft position sensor, it can't be fuel filter or injection since it start again after it cools down. good luck
| All times are GMT -5. The time now is 06:50 AM. |
