Transmission anyone?? HELP!!
Old Jul 11, 2007 | 10:20 PM
RADMANMOOSE's Avatar
Default Transmission anyone?? HELP!!
Hello,
my brother in law has a 2002 ML 320. apparently the transmission went into "limp mode". he took it to the dealer and they said it was a speed sensor was bad. they estimated about $1,200 to change it. The real kicker is they recomended changing the whole transmission, which they quoted $10,000!!! (because the transmission'sfluid was burnt).
Anyhow is it worth it for him to chsnge the sensor at a transmission place where it may be cheaper? does anyone know wheere to get the part or would it be dealer only? Is it an external part or internal? Or should he just buy a used transmission? if so where to get one? Please help. He can't afford to spend $10,000.
Thank youy so much for any help for him.
Old Jul 12, 2007 | 05:28 PM
NAZ's Avatar
NAZ
Default RE: Transmission anyone?? HELP!!
the sensor is fitted on to the hydro electric pad,which is found inside the box,to get to the pad remove gerar box sump, remove filter ,remove hydro pad its kind of black plastic tracker with a silver speed sensor ,you can buy the tracker on its on its about 115.00££,after renewel fill 6lts of MB ATF FULID ONLY WITH NEW FILTER,,,,, NAZ
o2pilot
Jan 28, 2018 03:12 AM
John Hubertz
Jun 9, 2010 12:07 PM
foothill999
Sep 4, 2005 12:27 AM
andygambia
Feb 21, 2005 08:36 AM
