PLEEASSEE HELP..BAS/ABS/ESP Light
Old Feb 24, 2010 | 10:53 AM
  #11
mbz connexion's Avatar
Originally Posted by mbenz80
That maybe setting procedure for the older original and replacement switches. New revision switch A 001 545 87 09 that I have installed to my ML in Nov.of 2009 did not have the adjustable plunger and works fine as plug and play procedure without any setting right out of the bag.
Bernard
Good to know.
Old Mar 20, 2010 | 02:58 PM
  #12
onitti's Avatar
Had the same prob alast year, and I first changed the stop lamp switch, a month later the BAS came on again and it turnd out to be the BAS sensor, I had that replaced and never had another problem with it. From what I was told the BAS system control engine power in a turn if the sensor is bad then its constantly telling the computer that the car is in a turn and that limits the amount of power delivered to the wheels. so if this is your problem you might notice you have to give more pedal when excelarting than normal which in turn burns more fuel.
C280 SPORT
Apr 16, 2022 02:45 AM
abcnerdd
Mar 20, 2010 02:38 PM
5 Salt
Nov 20, 2006 03:52 PM
GERMAN MAD
Oct 8, 2006 09:02 AM
rmt6668
Apr 28, 2006 05:53 AM
