-   Mercedes M Class (https://mercedesforum.com/forum/mercedes-m-class-16/)
-   -   O2 sensor heater problem Need help of specialists (https://mercedesforum.com/forum/mercedes-m-class-16/o2-sensor-heater-problem-need-help-specialists-9293/)
kora Feb 8, 2006 09:28 PM
Code - p0135. Changed o2 sensors, MAF, and plugs. CEL is still on. Data on wires: Grey ground - OK, Black sensor data - OK, White heater 12V -OK, white heater - no ground. Could not find a wire diagram anywhere.
Questions: Is it a wire harness problem? Is there a relay between O2 sensors and ECU? Where it is located. How to test if ECU grounds the sensor?
sleepwalker Feb 8, 2006 10:30 PM
RE: O2 sensor heater problem Need help of specialists
and what engine does that M-Class got?
kora Feb 9, 2006 05:01 PM
Sorry. ML320, 2000, 3.2 l engine. All 4 Os2 sensors have the same problem - heater. I am not aware of heater circuite diagram. Do the heater wires go directly to ECU or through a relay? Do they go separately to ECU (I doubt that), thus where is the meeting point? Thanks again
sleepwalker Feb 9, 2006 10:50 PM
ok, got it.
[IMG]local://upfiles/1/2407418D41C84930BA12CCEAC723B9AA.jpg[/IMG]
sleepwalker Feb 9, 2006 11:00 PM
[IMG]local://upfiles/1/394A22F904744AA09D53397B281DD5F5.jpg[/IMG]
[IMG]local://upfiles/1/627C2A35D9E545D5955C5C1585255FA3.jpg[/IMG]
[IMG]local://upfiles/1/2866AA043E9242DA903B7E95D38744A9.jpg[/IMG]
kora Feb 10, 2006 10:14 PM
Super. Thank you. So no relay, no common wire to the ECU. O2 sensors are working in pairs separately. The ECU transistors govern grounding of O2 sensors. I wonder if the ECU heater switch gets the signal from a temperature gage or from the O2 sensor itself? Can't read the ECU pin numbers, do you have a picture of ECU pins?
Thanks a lot
