noise problem need help ASAP
Old Apr 22, 2006 | 08:14 PM
MLbenzo's Avatar
Default noise problem need help ASAP
I have a 2000 ML320 and just recently when i start my car the engine makes this loud noise and when i start steering the wheels the wheels also make this loud sound. It's only when the engine is warmed up that the noise goes away but i never had any problem with it before. Can anyone tell me what's going on with my car?
Old Apr 24, 2006 | 08:00 AM
roygrider's Avatar
Default RE: noise problem need help ASAP
Sounds like the power steering pump, or its cooler...check the fluid in it. Hope this helps.
Old Apr 26, 2006 | 10:15 AM
LowKey's Avatar
I agree, it sounds like your PS pump is about to go. Does the noise sound like a whine? If it does then it is definately something wrong with your pump or something related like a PS hose could be leaking.
Old Apr 26, 2006 | 07:33 PM
MLbenzo's Avatar
thanks for all your help. so it seems that there were no more power steering fluid left so i fill it up last night and this morning the far was back to normal. Thanks again!! Another question i got for you guys..When you first start your car and drive off without it warming up does your ML hella lag and seems like it doesn't wanna go anywhere?? I usually have to warm up my car for like 2-4min for it to warm up before i drive off because if i just start my car and drive when the engine is cold my car goes hella slow/car hella shakes. Does your ML do that too or is it just mines??
Old Apr 28, 2006 | 08:26 AM
roygrider's Avatar
Yep...mine feels like I am stuck in low range or something, I read some where that 3 minutes was the perfect warmup time from a cold start up. Guess the fluids have to warm up for normal operation.
AmyNow
Jan 3, 2011 06:09 PM
MB 560sec
May 11, 2010 08:35 PM
demetriusrashek
Apr 19, 2010 11:05 AM
MB 560sec
Apr 1, 2009 02:10 PM
MLbenzo
Apr 24, 2006 02:20 AM
