Need Advice Many problems
Old Jul 17, 2005 | 06:50 AM
Fil's Avatar
Fil
Default Need Advice Many problems
My mum has a ml430 that has been terribly neglected as such many problems have arisen. I would like to rectify some of these myself before I going paying Merc too.
Would like to know if any of you guys have similar problems and how you managed to rectify them.
1. Passenger window wont go up ( suspect switch ) Do i replace all of the switches or just the faulty one ?
2. Faulty airflow sensor, I was wondering if these are interchangeable with any other models
3. The last problem is that it fails to drop into low range, and the low range light flashes upon start-upi have no idea what this could possibly be
Any help would be greatly appreciated
Cheers
Old Jul 17, 2005 | 10:06 AM
sleepwalker's Avatar
Default RE: Need Advice Many problems
we have many case of this and the switch really needs to change.
yes. for as long as newer engines.
does it flashes 4 times within 2 seconds? check the operating manual for the correct sequence. you never met the prerequisites required.
if not, then the actuator motor or the control module got problem.
skyhawk23
May 30, 2010 04:37 PM
solocreative
Jul 10, 2008 12:09 AM
gahmed
Jul 9, 2007 05:13 PM
valraven
Jan 2, 2004 11:42 PM
Amigoo
Nov 12, 2003 04:21 PM
