ML500 2006 Airmatic suspension light is on and battery sign
Old 08-19-2016, 02:25 AM
Gambit's Avatar
Angry ML500 2006 Airmatic suspension light is on and battery sign
Went to dealer and had it diagnosed as follows.
needs alternator and perform wiring repair 3.2 needs front sam and coding 3.4 and needs airmatic control unit 1.8 (alternator shorting someone installed voltage regulator and chewed up wiring from sam is shorting circuit 61, and airmatic control unit is shorted)
I had alternator checked, and it is putting out 14.2 v, and also the amp is fine.
So what is really going on here ? Yes i did had voltage regulator replaced, but thats it. No one touched SAM. My airmatic is not working, and its a rough ride, i bought a brand new battery which died after 15 days. Could it be just a relay that needs replacing? Why do SAM need reprograming ?
What is circuit 61 ?
Any help will be appreciated.
thank you
Old 08-20-2016, 09:57 PM
daemdaem's Avatar
Type in sam and Mercedes there is a couple of good you tube videos
Old 05-08-2017, 07:27 PM
Gambit's Avatar
I did, but there is nothing showing the location of FRONT SAM unit, or drawings.
ramella
08-29-2008 12:55 AM
peacemaker69
04-17-2007 03:04 PM
chepprey
11-28-2006 06:23 AM
rohitsagar
10-31-2005 04:48 PM
C280 wizard
11-16-2004 09:34 PM
Quick Reply: ML500 2006 Airmatic suspension light is on and battery sign
