Ml430 help
Hey everyone i have a 2001 ML 430 AMG and i just replaced the waterpump and when doing so i broke the water temp sensor....check engine light came one and i could not get the sensor for another week....replaced the sensor and light went away....
but the prob. that i am having is the three lights that are coming on mainly when i brake are the ESP/BAS....BRAKE.......ETS... i did look in the owners manual and i did see that the only thing common between the light were that if the system voltage drops below 10v then the light would come on.....but the thing is that more than those three should come on if that was the prob.. any suggestion welcome thanx |
anyone?
I believe that is time to replace your brake pedal switch! Search google and you will find the exact symptoms and replacement procedure. This has nothing to do with your broken temp sensor. Good luck!
