-   Mercedes M Class (https://mercedesforum.com/forum/mercedes-m-class-16/)
-   -   ML320 W164 couple of problems (https://mercedesforum.com/forum/mercedes-m-class-16/ml320-w164-couple-problems-50401/)
b0gd4n Jan 7, 2012 09:28 PM
I have an ML320 cdi from 2006.
The problems I have are:
- the left mirror does not adjust (only the right one works) - I have tried to look for the fuse, but I don`t know where it is - I only hope this is the problem;
- an error message keeps popping up in the instrument cluster about a bulb;
I have recently changed the left rear indicator bulb, but this works well most of the time, until the error appears. This is after using the left indicator for a bit. It then uses the reversing lamp instead of the indicator bulb.
This is reset after I restart the car.
What should I do about this.
Thanks in advance!
chassis221 Jan 8, 2012 10:57 AM
you probably have a bad mirror switch.
you could need a new tail light or a tail light harness update repair.
Moto One Jan 8, 2012 04:47 PM
We had a bulb that was not seated correctly, after reinstalling it all has been well.
Mark
