-   Mercedes M Class (https://mercedesforum.com/forum/mercedes-m-class-16/)
-   -   ML320 Shifter bushing (https://mercedesforum.com/forum/mercedes-m-class-16/ml320-shifter-bushing-2367/)
eddienaples Sep 4, 2004 07:28 AM
The shifter bushing has fallen out of the ML320 (2000) according to the dealer and the dealer wants $100 to replace. It looks like the part is less than $2.00 to buy. How difficult is the bushing to replace and exactly where is it located?
bbs138 Sep 7, 2004 02:47 AM
RE: ML320 Shifter bushing
you have tools just 10 mins, if not try to buy 2 more bushing ,you will break it easy.it dont have a lot of space to work on....:eek:
dipinj Jan 28, 2010 10:38 PM
does anyone have a step-by-step guide (or even pictures) to replace this Shifter Bushing? I have a ML430 and my dealer says that mine is missing as well.
mbenz80 Jan 29, 2010 11:34 AM
If you guys talking about little plasting bushing spacing out the shift rod in selector arm of the transmission, then you small flat screwdriver or small pair of long nose plyers to remove locking U-style clip from the end of the rod. About 2 minutes job under the car. I would trust my 11 years old son on this one!
Bernard
MB-TECH-38 Feb 14, 2010 10:51 AM
shifter bushing replacement
job is easy if you have right tools . there is 2 bushings 1 on bottom of gear lever n 1 on transmission selector lever both are hard on ground but with a lift no to bad with right tool. we charge half hour to do , bushing $ 5.00 each. bushing has a groove in center of it. this groove needs to split the lever you know half of bushing on one side of lever and other half on other side of lever.
i found making bushing soft will help [ i use a small torch ] but suggest hair dryer or couple seconds in microwave and spray silicone after soft . good luck
Jerry
