ml320 rough idle need help
Old Jun 12, 2007 | 07:54 PM
dis614's Avatar
Default ml320 rough idle need help
need help with 2002 ml320 rough idle code says cyl 3&6 tried swaping coil with cyl 4
code still read trouble with cyls 3&6
Old Jun 14, 2007 | 06:37 PM
joyanlili's Avatar
Default RE: ml320 rough idle need help
WHAT IS THE CODE..................YOU HAVE TO GIVE ME THE CODE.........IF YOU DON'T HAVE A CODE... GO TO AUTO ZONE THEY WILL HOOK UP THEIR SCANNER FOR YOU FREE OF CHARGE......
Old Jun 18, 2007 | 09:38 PM
Laterthatsameday's Avatar
Your EGR valve is stuck open
Old Jul 12, 2007 | 02:45 PM
kanderson510's Avatar
Hi...I just had a rough idle on my 2000 for about a month or so. Then this past Sunday my check engine light came on and it started running terrible. Autozone diagnostics said it as the #4 cylinder. We changed all of my spark plugs then diagnostics said misfire in #4 so we changed the wires and now it's running like a champ again. It probably just needs a good tune up. Good luck and if you know what you're doing, do it yourself...it'll save you lots of $.
Old Jul 12, 2007 | 03:39 PM
NAZ's Avatar
NAZ
you ii be very very supriesd,misfire on cylinders,even after swapin the coil packs,its your air mass sensor in other ways its called MAF,try a donour maf 95%its gonna run smooth,let me no hw u get on .........................................NAZ
madameboba
May 11, 2009 11:32 PM
Fitzgerald
May 2, 2008 10:53 AM
Fitzgerald
Apr 30, 2008 09:54 PM
fay3131
Sep 6, 2006 12:48 PM
