ML320 Burning Oil
Old Jan 4, 2005 | 02:54 PM
smryab's Avatar
Default ML320 Burning Oil
I doubt my problem is unique but here it goes: 99 ML320 burning oil at a rate of 1Qt every 400 miles or so. Now, I heard that there was a Class Action suit and that MB is suppose to fix the problem with MLs buring oil for free. Can anyone confim or deny that. Also, if MB will not fix it what do I do about it?
Old Jan 5, 2005 | 03:55 PM
sdanville's Avatar
Default RE: ML320 Burning Oil
try mercedesshop.com
go to the ML section and run a search. there is much written there.
Old Jan 6, 2005 | 06:38 AM
sleepwalker's Avatar
yes, there is a problem.
the piston, piston ring, and valve seals must be replaced.
Old Jan 6, 2005 | 02:24 PM
smryab's Avatar
Is MB responsible for the fix or is it my responsibility?
ORIGINAL: sleepwalker
Old Jan 7, 2005 | 02:11 AM
yes if the car is still relatively new and under warranty. depending on the dealer.
mercedes-benz germany have already acknowledge this problem which they might tell you stories such as fuel quality problem which reacts on the components, etc.
i myself have done at least 8 engines of this problem.
if you will remove the oil filler cap and see a thick sludge on it...then you got it.
removing the cylinder head cover and looking at the oil separator inside will show you some very strange accumulation.
Old Jan 14, 2005 | 11:33 AM
sdanville's Avatar
My 1999 ML320 used a quart every 600 miles. It used oil from new to 80,000 miles said the origional owner.
Now it uses one quart every 4500 miles. (103,000 miles currently)
All I did was 3 things.
1) origional owner used regular gas, thus the timing would be retarted and everything out of sync. I use Shell or Mobil Premium. I use Mobil One Synthetic Oil.
2) I had a carbon /sludge plugged egr tube. I cleaned it out. I cant imagine this was the cause as 1st owner said it used oil since new. The Mercedes service guy wanted $250ish to replace the whole EGR valve. Glad I didnt.
3) Several tanks of gas I used Gumout emmission control cleaner then Marvil mystery oil in the gas.
I submit that some emmission control part could be allowing oil consumption on many of these ML's.
Old Jan 31, 2005 | 06:46 PM
wmhunter's Avatar
Greetings to All:
There was a class action suit on this matter, which was settled in favor of the plaintiff class. Please see:
http://www.legalnewswatch.com/news_182.html
Good luck!
Kindest regards,
Bill Hunter
Old Jan 31, 2005 | 09:48 PM
sdanville's Avatar
Default Lawsuit ML owners Win - Hey Owners I have a Question.
I never got the $35.00 oil change Certificate from Mercedes..
Did Anyone ?
Old Feb 2, 2005 | 07:35 PM
  #9
samkshum's Avatar
I have a 2000 ML-320. It ran great from day 1 to about 50,000 miles with no oil burning issue.
Then after 50,000 miles, the engine started burning more oils than normal....about 1 qt per 3000-4000 miles. I used synthetic oil as well as premium gas.
Old Feb 3, 2005 | 10:51 AM
  #10
kevdog's Avatar
Default RE: Lawsuit ML owners Win - Hey Owners I have a Question.
ORIGINAL: sdanville
Did Anyone ?
I did get the certficate for my 98 ML320 a few years ago. I've never experienced any related problems, though.
