ML320, 1998 misfire on 1,2,3 cylinders
I have done an extensive search/experiments and kind of sure that it is my Right CAT that is at fault but before having it replaced I have one question.
My issue:
1. At first I got O2 Bank 2/Sensor 2 fault code.
2. After resetting and driving I got O2 Bank 2/Sensor2 and Sensor 1 fault codes. Reset it again and cleaned MAF sensor.
3. Got Misfire on 1, 2, and 3 Cylinders as well as as O2 Bank 2 both sensors under load. Decided to switch Coil #1 with Coil #4
4. The same, misfire on 1, 2, and 3 came right the way under load.
Without further due I concluded that it is my CAT 100%. Besides, it rootless when you gas it. It is a California car and emission is the key in here. The aftermarket CAT I was quoted costs $220 P+L that is not bad but not sure about quality.
Looking at the exhaust assembly I see multiple items:
1. CAT that sits between 2 O2 Sensors
2. Followed by a little resonator
3. Big resonator that combines both banks together.
Can someone please tell me if only CAT needs replacing or little resonator as well?
Thank you in advance.
My issue:
