Ml 320 2001 front power seats non operative Can I adjust manually?
Old Jan 2, 2018 | 02:11 PM
Noobie831's Avatar
Default Ml 320 2001 front power seats non operative Can I adjust manually?
Is there a way I can adjust the front seats manually ?
Old Jan 5, 2018 | 01:53 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! I was able to find the procedure to do this:
Remove both cushions and look straight down the white connector ***** between the motors at the front control the fore and aft motion these are very easy to see as they sit just in front of the control module. The seat cushion rake is controlled by the black plastic ***** almost under the front of the seat frame. The backrest angle is controlled by the motor on the inboard side of the seat back find a socket that fits the plastic bolt on the top gear for the toothed belt drive and turn clockwise or counter clockwise for the desired angle.
Rockerfella174
Aug 19, 2009 08:23 PM
mikelmco
May 17, 2008 07:02 PM
UncleMarkProductions
Jan 21, 2008 09:38 PM
Bugman
Sep 26, 2007 11:12 AM
Greg Z
Nov 7, 2006 01:02 AM
