mercedes ML270 cdi starting problems
Old 12-12-2018, 04:28 AM
Merc450se's Avatar
Default mercedes ML270 cdi starting problems
Hi all. about every 2 weeks and my 2005 ML270 CDI, runs for a couple of seconds then dies and will not start at all.
I have found that if I bleed the number 1 injector it starts and last for about 2 weeks and then have to repeat again.
Anyone got any idea to solve this problem.
many thanks
Old 12-13-2018, 05:46 PM
Hello and welcome to the forum! Before you spend any money on parts, I would recommend pulling the car's codes. This should give you a good idea where the issues is coming from. Please let us know if you have any other questions or if we can assist with any future part needs.
Old 12-14-2018, 03:52 AM
Merc450se's Avatar
Hi, thank you for the reply and unfortunately, it not bringing any codes and I'm thinking it could be a bad injector problem
Old 12-20-2018, 02:37 PM
If the issue is with the injector, there should be a misfire happening as well. Try switching the injectors around to see if only the #1 is affected.
Old 04-12-2020, 04:03 PM
Turhan's Avatar
Default 270 CDI not starting .
We had the same problem and after searching for a long time this was the problem :
between the filter mounted on the engine and the high pressure diesel pump there is a tube which clicks in the filter and the pump .
take out this tube ; it has on both sides o rings to seal it off .
These O rings are not sealing properly anymore and the pump pulls air ; replace them or buy a new tube with seals .
Temporary remedy we did and for over a year we have the new rubbers but no need to install it so far : take sewing machine tread , rap about 5 - 10 times in the O ring seat , replace old O ring and push in it ; goes in hard .
Prime and start !!
ctedder
10-07-2019 01:41 PM
farid
11-23-2016 11:45 AM
sheldonblack
04-14-2011 05:16 AM
bigkhodge
11-22-2007 06:10 AM
beastie40
11-18-2007 12:46 AM
Quick Reply: mercedes ML270 cdi starting problems
