-   Mercedes M Class (https://mercedesforum.com/forum/mercedes-m-class-16/)
-   -   MAF Sensor for '99 ML320 (https://mercedesforum.com/forum/mercedes-m-class-16/maf-sensor-99-ml320-48391/)
superd270 Jun 2, 2011 01:18 PM
Can somebody help me with the pin out assignments for the MAF sensor on a '99 ML320?
Which pins do I check for the 1.4 ~ 1.7V signal?
Thanks.
superd270 Jun 3, 2011 06:24 PM
Currently working on the ff DTC Codes:
PO 105 - Manifold Absolute Pressure, BARO Circuit
PO 173 - Fuel Trim Bank 2
PO 156 - O2 Ckt, Bank 2 Sensor 2
PO 170 - Fuel Trim Bank 1
Two pending:
PO 400 - EGR Flow
PO 155 - O2 Htr Ckt, Bank 2 Sensor 1
New MAF arriving Tuesday. Hoping to address 105, 170, 173. Then replace Bank 2 Sensor 2 O2 sensor.
When replacing O2 sensors, does it make sense to replace both of them or just the faulty one?
Will update developments next week.
superd270 Jun 29, 2011 12:49 PM
Took a while but here's some progress.
PO156, PO173, PO155 are now all gone after replacing the O2 sensors.
PO105 and PO170 still lingers even after replacing MAF with a new one fm ebay.
What further action/checks can I do to fix the PO105 (Manifold A
bs Pres, BARO Circuit) trouble code? Should I buy another MAF and replace it again?
Would appreciate all help and advance thanks.
Danny
sobenes123 Jul 23, 2011 08:14 AM
call 630 8547567 mercedes mechanic in illinois 630 8547567
close to rt 19 and rt 59
