just got 98 ML320
Hi, I got a 98 ML320 and I have following problems.
problem 1: SOmetimes when I turn the key it does not start, sometimes it does. problem 2: After driving a while 'BRAKE' light comes on on the instrument cluster and transmission gets stuck in second gear. It feels like its a fail safe mechanism to prevent you from going fast. What causes BRAKE light to come on? and why does it affect the transmission? If I shut down the engine and restart then it works fine. problem 3: AC is blowing hot air from all vents. problem 4: Power locks make ticking sound from driver door and unlocks and then locks by itself all four doors. Other then that its a great car. Please help soon. |
I am the original owner of a 99 ML320. At 154K, the 3.2L engine still drives like new, with regular synthetic oil changes.
I had the same starting problem (your Problem 1) about 4 years ago. After replacing the fuel pump and a sensor (might be the O2 sensor but I do not remember now), the problem is gone. A good and experienced mechanics can help diagnose the problem with meters. You can also go to a dealer, but it will be more expensive. I can not help your other problems. |
