HELP--Need to replace Brake Light Bulb
I am trying to replace the light bulb, but I can't get the tail light out. I unscrewed two screws but the tail light won't come out. I just don't want to break anything, is there anything else I need to do? Thanks for the help.
RE: HELP--Need to replace Brake Light Bulb
After you take out the screws, you will simply have to pull hard (held in by plugs)
well Brigader,
I replaced a brake light a couple weeks ago. I pulled and pulled on the lense with my short fat fingers. Then i took a nail bar and pryed it off. a couple plastic parts cracked off the interior. These are not like Honda's to work on - they are more like Chyslers. The plastic I broke off was not critical thank goodness. I sprayed silicone all over it when re-installing for next time. I was happy to see it took the old style cheap 1156 or 1157 bulb (cant remember which). Good luck. |
