ETC light on ML 270
I was wondering if anyone has an idea on what is causing my ML 270 diesel to misbehave?</P> It is a 2003 with only 15.000 Km on the clock. </P> Atoday the EPC light came on, with a subsequent loss of power, it sounded if the fuel injection pump had been retarded. On re-starting the engine it was fine below.</P> Does anybody know what appened?</P> Any input would be gratefully received</P> Many thanks</P> |
RE: ETC light on ML 270
:eek:ETS Control Mode
Brake intervention - both wheels • Both rear wheels at least 2.8 km\h (1.7 mph) faster than vehicle speed + • Cornering recognition: Speed difference between left and right front wheels > 1km\h (.6 mph) + • speed range = 15-80 km\h (9-50mph) • On period: maximum of 2 secondsTemperature Monitoring To prevent brake overheating in exceptional cases, brake temperature is calculated. If maximum:eek: temperature is reached ETS is cancelled. Driver is notified my the MIL Temperature is evaluated separately for each rear wheel based on: • Vehicle speed • brake operation • Calculated brake pressure |
[8D]Engine Torque Reduction
If wheel spin is recognized at both rear wheels, the traction control module request an engine torque reduction from the ME control module via the CAN. The ME control module can reduce engine torque by: • Retarding the ignition timing • Closing the throttle plate ASR Functions Below 40 km/h(25mph),1 Wheel slips ,Brake applied First ,Throttle controlled Second 2 Wheels slip ,Throttle controlled First ,Brakes applied Second Above 40 km/h(25mph)Throttle controlled First,Brakes applied Second Throttle controlled First, Brakes applied Second Turns, 20-120km/h(12 to 75mph) Throttle controlled First ,Brakes applied Second (With lower slip threshold) Throttle controlled First ,Brakes applied Second:eek: |
ABS - Anti-lock Brake System
ASR - Anti Skid Regulation BAS - Brake Assist System EBR - Engine braking regulation EBR - Engine braking regulation ETS - Electronic Traction Support IC - Instrument Cluster MIL - Malfunction Indicator Lamp SPS - Speed Sensitive Steering 4 Matic - All wheel drive but etc ????[&:]b |
:Dfinal i find this
Hidden Changes Shift Into Optimal Gear (SOG) Function • With the gear lever held in the “D-” direction, the ETC control module calculates the gear which provides the best possible acceleration or deceleration. • Selecting and holding selector lever in the “D+” direction, the transmission shifts directly to “D”.:eek:b |
