cruise control
I have this car from 1 month, (2002 Mercedes ML320 ) and I have a problem, pls help me. The cruise control doesn't work anymore...is worked ...if somebody can tell my ...thx
RE: cruise control
wrong tire sizes from the left side to the right side? did you get new tires? traction control issues? faulty brake switch? check to see if the brake lights are on all the time, that will cause no cruise control. also check fuses.
RE: cruise control
Thx for answer, will check
RE: cruise control
Yes, I check and the problem is the stop light they stay on all the time ...know is a big problem ....probable I have to go to a garage...I hope is not big deal
RE: cruise control
easy fix you can do it yourself if your somewhat mechanical it just twists to come out and a new one goes in the same way. just push the little tab in then twist.. when you install the new one pull the button out on the switch( the new stop lamp switch then install). obviously remove under dash panel first ...2 or 3 phillips screws
