Codes (lots of them)
Old Oct 30, 2006 | 02:16 PM
AdiB's Avatar
Default Codes (lots of them)
I'm trying to figure out if I can treat the Mercedes codes the same as VW codes. For example: cylinder misfire code on my vw came up and I had to replace a water temperature sensor. Now the code for a cylinder misfire came on a mercedes does it mean the same (water temperature sensor) or is it something else. and here are all the codes its' spitting out, if someone can help me out I'd appriciate. I really dont want to take my car to a mechanic I'd like to fix it myself.
P0170 Fuel Trim
P0173 Fuel Trim Malfunction
P0302 Cylinder 2 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0170 Fuel Trim
P0304 Cylinder 4 Misfire Detected
P0300 Random / Multiple Cylinder Misfire Detected
Thank you.
Old Feb 9, 2007 | 09:59 PM
C280owner's Avatar
Default RE: Codes (lots of them)
How come on a cylinder misfire code you had to replace the water temperature sensor ? Doesn't a cylinder misfire code mean you need to replace the sparkplugs (or have a tune-up ?)
Old Feb 11, 2007 | 11:21 AM
sdanville's Avatar
Default The answer is "No".
To my knowledge Misfire codes on a mercedes isnt a tempature sensor.
Run a search and you'll find lots of Mass flow air sensors replaced as well as Ignition wires and plugs.
Old Feb 15, 2007 | 05:26 PM
bardia05's Avatar
It happen to me too;
Change the Spargplugs all of them (TUN-UP)and wires.you'll be fine.
Pverduzco
Aug 31, 2009 10:15 PM
boywonder
Jul 18, 2006 10:41 PM
Supershyguy
Jul 5, 2005 01:21 PM
toothlessracer
Nov 27, 2004 08:40 PM
MB/TECHMAN
Oct 29, 2004 10:41 PM
