cd changer will not eject
New to the form. And my first post is a question.....:confused:
The cd changer in my ML 320 will not eject the CD case. The eject button in the trunk, only blinks when selected. Any one ever experience this problem? |
what i do that usually works is bang on the magazine with your fingers as you pressing the button. keep trying and eventually it comes out. or sometimes a disk gets jammed and it wont pull back into the magazine so you sometimes operate the cd changer and play the cds and switch from disk to disk and retry ejecting the magazine. then if none of those things work youll need to get inthere with something and try to push the disk into the magazine and sonetimes youll have luck.
Like he said above.
You can look into the changer and see if a disc is caught between the magazine and drive system. |
cd's
don't have any other trick to get CD out but , if you do get it out MB player's do not work well with home made CD's just my 2 cents here
Jerry |
I usually remove the player, take off the cover and spin the large wheel on the underside of the player.
I don't know what causes the jamb but once the CD is removed the player usually works good again. |
