Another fuel guage? diff fuse box
hello to all,I have a 1999 Mercedes ml 320 I have read several post in regards to trying to remove fuse #5 to re set the fuel system,now they say the fuse box is under the passenger side floor.That is only on newer models mine is located in the engine compartment so I looked for fuse #5 and it is not what the post is saying.so would it b a relay?Can someone tell me so I can be clear on what the fuse should say?or if it is a fuse or a relay?Thanks to all:o
try passnegr side floor, the side kick panel under the dash. some fuses and relays there.
Really weird i removed the plastic shield uder the passenger side by ur feet the only thing i c is the blower motor and a few other thing but nothing that looks like fuses or a fuse box
Originally Posted by ml3204life
(Post 157925)
Hello again,I see that the newer model has the fuse box in the car the 1998-2000 had all the fuses in the engine department now I read on another thread that another guy un hooked the power from the rear driver side to re set the float.Well I looked in the rear and seen 2 sep harness but not sure witch one is the one to un hook.Any help on what wire to un hook?Thanks to all :confused:
| All times are GMT -5. The time now is 06:02 AM. |
