-   Mercedes M Class (https://mercedesforum.com/forum/mercedes-m-class-16/)
-   -   99 ML430 code P0443 (https://mercedesforum.com/forum/mercedes-m-class-16/99-ml430-code-p0443-42511/)
heretic May 8, 2010 04:39 PM
99 ML430 code P0443
I have a 99 Ml430 with a code P0443. I know a purge valve needs replaced but I was told there are a couple on the car. Does anyone know which one needs replaced or how to find out which one needs replaced?
chassis221 May 8, 2010 06:36 PM
there is only 1 purge valve. its drivers side under the hood near your throttle cable and throttle position sensor. its beside the engine, it has a rubber thing around it to hold it to the bracket. will have 2 rubber hoses or plastic hoses attached to it and also an electrical plug.
heretic May 8, 2010 07:51 PM
Do you know a place besides Mercedes where I can get the purge valve?
