2011 MB - OM 651 cdi
Hello
Does anyone have a tip to diagnose these? ML 250 cdi. w166. vin WDC1660041A005379 - The car stops at the intersection or sometimes when its put into gear. It’s also coughing and almost stops before it runs again. -The EZS, ECU, Throttle body, Battery, Dynamo, is changed, and still no change. There is no wiring problem?! have overlooked it. All others canbus have a signal. The Benz dealer gave up so now it’s my turn to try to find what’s wrong. The car does not have keyless go.... ******* EZS - Electronic Ignition lock(N73) 1 problem exists 1.U10382A Communication with the diagnostic CAN bus has a malfunction. There is no signal change. IC - Instrument cluster(A1) 1 problem exist 1.U114587 Communication with KEYLESS GO has a malfunction. The message is missing. ECM - Engine Control Module (CDI) 1 problem exist 1.P061B85 The torque calculation of the control unit has a malfunction. There is a signal above the permissible limit value. STORED DTR - DISTRONIC(A89) 1 problem exist 1.630200 CAN communication with control unit ''N62/1 (Radar sensors control unit)'' or ''N30/4 (Electronic Stability Program control unit)'' has a malfunction. |
| All times are GMT -5. The time now is 12:42 AM. |
