2001 ML320 Key Remote stopped working...best solution?
Hi, all
I have three keys form my 2001 ML320 but only one worked with full functionality and the others didn't. Once my third key stopped working, I finally read the manual and found that you can try re-syncing if the remote didn't work. So I tried it by key in ignition to 2, then key out, the press unlock button five times while holding lock button within 10 seconds when pulled out and when I press lock or unlock button, I see that my car locks or unlocks indicating there's connection from the key to the car, but it only works once. Then the key wouldn't work again. I tried this with other two keys (the others that I thought it broke), and it does same thing. So there is connection, but no more than that. I went to the dealer to if there is a solution, and as I heard it before, my service manager tells me "get a new key for $375" Now I am upset that I need to put out such $$ for inferior product that goes bad continuously as I already bought a new key 3 years ago. I googled a little to see if there's a solution and found it could be AAM problem (What is AAM?) which will cost around $600. or get seperate alarm...... If replacing AAM enables my all three keys, I just might do that, but I want to make sure before I proceed. Does anyone know about this? or is there a firm solution for this key thing..... Thanks in advance. |
Hi Todesto,
you are not finalizing your programing. That is why they are working but only ones. Your keys are OK. With all doors closed: 1. turn key to pos. 2 then back to pos. 0 and remove it. 2. within 10 sec. press and hold lock button. 3. Now push unlock 5 times while still pressing down lock button. 4. Release lock button. You came all the way to this point but there is one more step to re-synchronization. 5. PRESS TAIL GATE BUTTON TO COMPLETE SYNCHRONIZATION. This last step is not mentioned at all in my original 1999 ML320 owner's manual. But it workes, I got two remotes working for my Ml thisway. Bernard |
Thanks, but no luck. I tired it but won't do anything.
Is 1999 and 2001 model same? |
Thanks So much Benz80!
I just purchased a 2000 ML320 and one of the keys I got would not work.
I tried several instructions to reprogram and nothing worked until I read your post and tried that last detail about the tailgate button. It worked like a charm. Saved me a lot of money. Thanks Again! |
Originally Posted by mbenz80
(Post 131497)
Hi Todesto,
MBENZ80
Thank You. The instructions in the owners manual did not work. Neither did many other solutions that I found on the Net. However, yours worked perfectly. I am now a happy Benz owner.:) |
Works like a charm!!! Thanks!
im having the same problem, any solutions?
Same Problem!!!! The Trunk Lock doesnt fix it for me.
It flashes and thats it. If I press the Trunk lock after releasing the Lock button, it just unlocks the trunk once and thats it. Please help. |
Originally Posted by babbar187
(Post 165241)
same problem!!!! The trunk lock doesnt fix it for me.
It flashes and thats it. If i press the trunk lock after releasing the lock button, it just unlocks the trunk once and thats it. Please help. |
