2001 ML320 Key Remote stopped working...best solution?
Old 01-20-2010, 07:23 PM
todesto's Avatar
Question 2001 ML320 Key Remote stopped working...best solution?
Hi, all
I have three keys form my 2001 ML320 but only one worked with full functionality and the others didn't. Once my third key stopped working, I finally read the manual and found that you can try re-syncing if the remote didn't work. So I tried it by key in ignition to 2, then key out, the press unlock button five times while holding lock button within 10 seconds when pulled out and when I press lock or unlock button, I see that my car locks or unlocks indicating there's connection from the key to the car, but it only works once. Then the key wouldn't work again. I tried this with other two keys (the others that I thought it broke), and it does same thing.
So there is connection, but no more than that.
I went to the dealer to if there is a solution, and as I heard it before, my service manager tells me "get a new key for $375" Now I am upset that I need to put out such $$ for inferior product that goes bad continuously as I already bought a new key 3 years ago.
I googled a little to see if there's a solution and found it could be AAM problem (What is AAM?) which will cost around $600. or get seperate alarm......
If replacing AAM enables my all three keys, I just might do that, but I want to make sure before I proceed. Does anyone know about this? or is there a firm solution for this key thing.....
Thanks in advance.
Old 01-22-2010, 12:33 PM
mbenz80's Avatar
Hi Todesto,
you are not finalizing your programing. That is why they are working but only ones. Your keys are OK.
With all doors closed:
1. turn key to pos. 2 then back to pos. 0 and remove it.
2. within 10 sec. press and hold lock button.
3. Now push unlock 5 times while still pressing down lock button.
4. Release lock button.
You came all the way to this point but there is one more step to re-synchronization.
5. PRESS TAIL GATE BUTTON TO COMPLETE SYNCHRONIZATION.
This last step is not mentioned at all in my original 1999 ML320 owner's manual.
But it workes, I got two remotes working for my Ml thisway.
Bernard
Old 01-22-2010, 05:22 PM
todesto's Avatar
Thanks, but no luck. I tired it but won't do anything.
Is 1999 and 2001 model same?
Old 01-26-2011, 12:34 AM
slsmith97321's Avatar
Default Thanks So much Benz80!
I just purchased a 2000 ML320 and one of the keys I got would not work.
I tried several instructions to reprogram and nothing worked until I read your post and tried that last detail about the tailgate button.
It worked like a charm.
Saved me a lot of money.
Thanks Again!
Old 12-14-2011, 10:24 PM
Cavhorse's Avatar
Thumbs up
Originally Posted by mbenz80
Hi Todesto,
Bernard
Thank you so much! Worked perfectly on my 2001 ML320.
Old 09-08-2012, 01:15 PM
LRader's Avatar
Default Thanks
MBENZ80
Thank You. The instructions in the owners manual did not work. Neither did many other solutions that I found on the Net. However, yours worked perfectly.
I am now a happy Benz owner.
Old 06-29-2013, 10:02 PM
WilliamCVelasco's Avatar
Works like a charm!!! Thanks!
Old 08-24-2013, 11:54 PM
moniquemapp's Avatar
im having the same problem, any solutions?
  #9
Old 12-30-2013, 10:22 PM
babbar187's Avatar
Same Problem!!!! The Trunk Lock doesnt fix it for me.
It flashes and thats it. If I press the Trunk lock after releasing the Lock button, it just unlocks the trunk once and thats it.
Please help.
  #10
Old 01-02-2014, 07:38 PM
babbar187's Avatar
Originally Posted by babbar187
same problem!!!! The trunk lock doesnt fix it for me.
It flashes and thats it. If i press the trunk lock after releasing the lock button, it just unlocks the trunk once and thats it.
Please help.
bump??
Quick Reply: 2001 ML320 Key Remote stopped working...best solution?
