2001 ML320 door lock problem
Hi, I have a 2001 mercedes ml 320 and the driver side door actuator broke and ever since then the remote buttons for door locks and etc on key dont work. I tried my other key and it doesnt work either. Is there a reset procedure for the key door locks? Is there a fuse or relay or something I can check for the door locks? anyone know where i should start? Thanks, Danny
mili,
key can be reprogramed at dealer or independent shop that has the right computer to do so .
and at same time shop can make all doors lock & unlock to see if all are in working order or which doors need lock assemblies. [ common problem bad locks ]
Jerry
Jerry
I have similar problem. But in my case the stealership broke my power lock door system. It worked perfectly when i brought in for service. The service manager asked me if door locks work, I said they work fine, I showed him. He said for older ML door locks fail.
I pickup my ML after service, low and behold, door locks no longer work. He said it's the key batteries, had them replaced and still doesn't work. Stealership wanted $120 bucks to trouble shoot. They said it's some kind of accuator that failed. Approximately $400 to fix. I think the stealership some how shorts them out.
legenesepimp
Nov 2, 2005 05:04 PM
